It is currently Thu Jun 11, 2026 6:28 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: My latest project...
PostPosted: Wed Sep 23, 2009 9:02 am
Not a LUV, but it was cheap...
 Post subject: Re: My latest project...
PostPosted: Wed Sep 23, 2009 10:54 am
Could be fun, big block???
PostPosted: Wed Sep 23, 2009 12:22 pm
Nah, it's set up for a small block. Since I got the headers and mounts, I'm thinking Vortec...
PostPosted: Wed Sep 23, 2009 12:27 pm
I got everything but the engine. It has a fresh turbo 350, a B&M Holeshot convertor, floor shifter, heddman shorty's, 3 inch Borla exhaust, a Howe aluminum radiator, I got the swap mounts also. The rear is a 8.5 out of a Grand national, 4:10 with a locker. The hood is a bolt on Harwood, the paint is Hugger orange and just needs a cut-n-buff, and the interior is a custom grey/black tweed on the seats, with the rest stock black. I got the ac compressor also, and the nitrous kit...
PostPosted: Wed Sep 23, 2009 9:02 pm
Nice find!!
PostPosted: Wed Sep 23, 2009 9:21 pm
Just picked up a sweet little 327...
PostPosted: Wed Sep 23, 2009 9:30 pm
:D
PostPosted: Thu Sep 24, 2009 8:43 am
Keep us posted on this one .
PostPosted: Sun Sep 27, 2009 6:09 pm
Leakdown on the little 327 was great. Shooting for an install next weekend...
PostPosted: Fri Oct 30, 2009 8:00 pm
Took it out for a spin today. I have a few minor things to finish before I bring it home, but it is pretty sweet. It drives, stops, steers like it should. I have to replace the door hinge bushings on the drivers side, work on the window track that side also, replace the speedometer cable, and charge the AC...
__________________
PostPosted: Tue Nov 10, 2009 10:32 pm
Hey, when are you going to start on that LUV you got from me? Your'e keeping her sheltered and well fed I hope! :D
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Tue Nov 10, 2009 11:34 pm
Errrrr... 8O
PostPosted: Sun Nov 15, 2009 1:43 pm
That's what I thought! Not feeling the LUV here mytmouz....
Rick
Loranger, La
PostPosted: Sun Nov 15, 2009 9:06 pm
__________________
Got it home and detailed. I was letting it idle for a few while I was getting ready to take it out for an extended cruise. heard a noise and shut it down. This was yesterday. Trailered it to my buds shop and we did a little investigating, only made a noise after it came up to temp, decided to pull it out and tear it down. Did that today. Whoever built the engine (new Speed Pro flattops, worked stock rods with L19 bolts, 268 comp cam) had the torque specs too tight on the main bolts and it wiped the front bearing and the crank. Pulled a fresh .010/.010 small journal steel crank from the parts stash and cleaned it up. Waiting on bearings...
PostPosted: Wed Nov 18, 2009 7:50 pm
Bummer.
PostPosted: Sat Nov 28, 2009 3:50 pm
Got it running and been driving it around. It is a Hugger Orange 1987 S10 Blazer with a few mods consisting of a bolt on fiberglass Harwood cowl hood, Eibach lowering kit, Lakewood traction bars, Heddman shorty headers with a 3 inch dual exhaust, Borla stainless mufflers and turndowns, 3:73's with a posi unit, a fresh turbo 350 with a hard shifting shift kit, a B&M Holeshot convertor, B&M ratchet shifter, a few custom interior touches such as an overhead console and a Grant steering wheel, Sony stereo system, and lastly the engine. It is a 1962 small journal 327 bored .030, stock polished rods, with L19 bolts, an .010/.010 steel crank, Cloyes double roller timing chain, a Comp Cams 268 hydraulic flat tappet camshaft. Up top is a set of 1969 441 300 horse 350 heads with 2.02/1.6 valves, an ancient Holley dual plane factory manifold, and a 600 Holley carb. It has a large aftermarket aluminum radiator that keeps the temps at 160 after a 25 mile cruise, and I used a 1989 Firebird serpentine belt set up for the accessories. The AC is functional...
PostPosted: Sat Nov 28, 2009 5:00 pm
I dont want to scare you but one pic has a Ford in it.
PostPosted: Sat Nov 28, 2009 6:51 pm
Don't remind me...
PostPosted: Sat Nov 28, 2009 9:02 pm
WOW... It is going 55mph with no driver...
PostPosted: Sat Nov 28, 2009 10:23 pm
One of the glitches i have left to mend, though it works while in motion...
