It is currently Tue Jun 30, 2026 12:16 am
PostPosted: Fri Mar 21, 2008 12:37 am
I dont know why I have to stop my car by pulling a bit of wire out of the dash...any takers on this one...? Seems a bit wierd and is their a way around it?
cheers
shaggs
PostPosted: Fri Mar 21, 2008 4:04 am
Australian LUV Guru
That piece of wire is hooked to a butterfly on the intake of the engine, when pulling the wire it closes the butterfly. This starves the engine off air and stalls/stops it. Shagg's are you sure your Luv is a 1980? It sounds to me like you have a much earlier series, drum brakes, column shift etc.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Fri Mar 21, 2008 5:14 am
Australian LUV Guru
Shagg's, I visited your myspace page and checked out your pictures. I now know why you have to pull the wire to stop your Luv. The wire in your Luv has been disconected from its solenoid, the wire in the picture(#1) should be hooked up at position (#2)
HERES SOME PICS OFF MY ENGINE BAY
PostPosted: Sat Mar 22, 2008 2:08 am
Hi Mate, I wonder why someone woould do this modification...any sugestions? Plus my car is a 1980 mlodel as it is stamped on the vin plate.
cheers shaggs
PostPosted: Sat Mar 22, 2008 5:05 am
Australian LUV Guru
cheers shaggs
The previous owner most like'ly made this mod because the solenoid no longer worked.
