It is currently Sun Jun 28, 2026 8:46 am
PostPosted: Mon Apr 09, 2007 2:52 pm
An elderly lady phoned her telephone company to report that her telephone failed to ring when her friends called - and that on the few occasions when it did ring, her pet dog always moaned right before the phone rang. The telephone repairman proceeded to the scene, curious to see this psychic dog or senile elderly lady.
He climbed a nearby telephone pole, hooked in his test set, and dialed the subscriber's house. The phone didn't ring right away, but then the dog moaned loudly and the telephone began to ring.
after climbing down from the pole and doing a little investigating work, the telephone repairman discovered the following:
1. The dog was tied to the telephone system's ground wire via a steel chain and collar.
2. The wire connection to the ground rod was loose.
3. The dog was receiving 90 volts of signaling current when the phone number was called.
4. After a couple of such jolts, the dog would start moaning and then urinate on himself and the ground.
5. The wet ground would complete the circuit, thus causing the phone to ring.
Which absolutely demonstrates that some problems clearly CAN be fixed by a lot of pissing and moaning.
