It is currently Fri Jun 12, 2026 2:13 pm
PostPosted: Sun Apr 09, 2006 9:32 pm
Can I get some pics posted of the original rims and their respective center caps?
Thanx!
72 L.U.V.
427 SBC-700R4
Mustang II front suspension
LUV perf parts manufacturing
My Devotion to Karl :
PostPosted: Sun Apr 09, 2006 11:53 pm
What year? Most came with basic steel wheels, no center caps just a plain hub cap that covered just the middle part of the wheel. A larger chrome hubcap was also available for most years that went out to the edge of the wheel.
4x4s came with a plain white spoke wheel, and an optional center cap. I believe the same wheels could be ordered with center caps on 2WDs too.
There was also a special version with spoke wheels with heart shaped cut outs. Not all that common though.
PostPosted: Mon Apr 10, 2006 8:02 am
was looking for the ones having the small center cap in the middle covering the lug nuts!
72 L.U.V.
427 SBC-700R4
PostPosted: Mon Apr 10, 2006 8:29 am
check this gallery......
http://www.luvtruck.com/Gallery/Stevens72ArcataCA/index.html
PostPosted: Mon Apr 10, 2006 3:11 pm
Yeah that is a good suggestion. Look through the galleries on the main site here and you should find several examples. On the base model hub caps there were a few minor changes across the years but they are all pretty much the same. If I get some time I'll try to dig out the few base model hub caps I have around, assuming I can find them.
PostPosted: Mon Apr 10, 2006 10:03 pm
Roadshow Bob,
I looked at that truck, and I did go thru the images posted on the site.
That truck is hard to make out the center caps.
I bought 2 over the weekend I think are LUV caps, they are mint!
I was thinking of looking for the rims that match these caps...
Were the original rims with these center caps slotted in the center piece of the rim, kind like a Corvette rally rim?
800xl...
I would really like to see those caps...
rims anyone?
72 L.U.V.
427 SBC-700R4
PostPosted: Mon Apr 10, 2006 11:10 pm
http://forums.luvtruck.com/viewtopic.php?t=9642 full wheel covers
PostPosted: Mon Apr 10, 2006 11:26 pm
Those are nice...
The center caps I picked up over the weekend are painted white and have a GOLD/Yellow BowTie with a white base paint; they arent a full hubcap like these!
72 L.U.V.
427 SBC-700R4
PostPosted: Mon Apr 10, 2006 11:38 pm
Here is one I found with a typical looking stock wheel without any cover on it:
http://www.luvtruck.com/Gallery/EthneCr ... index.html
It isn't the best picture, but it should get you some idea. The cover on the front wheel is the most common stock chrome type. That style hooks against the outer edge of the rim, so they would fit most all 14 inch steel wheels. The base model style that fit over just the middle of the wheel would be more specific to the right wheel I'd think.
I hope to get some time, but its not looking good this week. If I do find some time I can get you some pics of both standard stock rims and whatever wheel covers I can find.
PostPosted: Mon Apr 10, 2006 11:54 pm
Here is another stock rim minus hub caps. It is hard to see, but note the three little nubs that stick out in the ridge around the lug nuts. Its hard to see, but they are at about 12, 4, and 8 o'clock positions around the rim.
http://www.luvtruck.com/Gallery/Project ... v-bed.html
PostPosted: Tue Apr 11, 2006 8:14 am
Would the 72-76 caps appear different than the aluminum one I see here?
72 L.U.V.
427 SBC-700R4
PostPosted: Tue Apr 11, 2006 11:12 am
if you check this brochure..http://www.luvtruck.com/pdf/79Dlr-Brochure.pdf ... you can see the later style full wheel covers and on page three is a decent shot of the small hubcaps
PostPosted: Tue Apr 11, 2006 12:02 pm
Aluminum one you see where? If you mean in one of those pictures I posted, its chromed steel. I don't have my parts manual with me to tell you the exact year, but the deluxe hub caps are a little different on the older trucks.
PostPosted: Tue Apr 11, 2006 6:51 pm
800xl...
I was loonking at Ethne Crook's red(?) LUV with the right
front cap
72 L.U.V.
427 SBC-700R4
PostPosted: Tue Apr 11, 2006 6:56 pm
Roadshow Bob's flyer has them!
That's the rims/caps I am looking for!
The Blue 79 shortbed on page 3, and the stake bed on page 8 has them.
The 2 caps I found at the swap meet are those!
So, I am looking for those rims and 2 more center caps...
8)
72 L.U.V.
427 SBC-700R4
PostPosted: Wed Apr 12, 2006 11:12 am
8)
i have two of the rim with tires, i had the center caps but they were bent up pretty bad so i threw them away , i think. if i can find my camara ill take a few pics of them if you want them.
PostPosted: Wed Apr 12, 2006 12:04 pm
I probably have a dozen of the wheels around, having 9 LUVs they tend to collect up. I don't know how many of them I could part with though, I like to keep all my parts trucks at least a little mobile. Much easier to tow them around with rubber under them.
I know I have a few of the hub caps, but I have not seen them in a good long time. They are probably stuck in the one parts truck I have tucked way down in the woods. If I get off work early enough tonight I'll go look.
PostPosted: Wed Apr 12, 2006 9:39 pm
OK, let me try 800xl 1st, seeings he is closer...
I'll await your reply...
Thanx!
UPDATE: 4-16-06
800XL. I found a set of rims locally.
I could still use 2 nice white center caps!
Thanx!
8)
72 L.U.V.
427 SBC-700R4
Users browsing this forum: Baidu [Spider] and 20 guests
