It is currently Tue Jun 16, 2026 1:58 am
 Post subject: my truck rocks...
PostPosted: Fri Jan 12, 2007 10:55 am
So i still have that nagging charge light issue, the cheap and easy fix was to unplug the heater. Now its been vary cold here lately, im betting probly 20s this morning. So i scrape my windows and it dosnt do anything for visability. So i scrape the inside of my windows, that worked for about 1minuet. Then the heat coming off the cowl of the truck put a heavy fog on the windows that wont wipe away. At this point i im kinda wondering if i should turn around and walk to work. Then i see the ray of hope, the heater will give you heat with no motor becouse its a constant flow set up. Theres always air passing through the heater core so it start defrosting the windshield a little bit. So what do i do, i drive faster to force more air through the heater core and BAM, defrosted. Well enough to drive around anyway. Man this truck is awsome... :lol:
PostPosted: Fri Jan 12, 2007 11:17 am
My heart 'bout stopped when you said BAM, I thought you had relocated another telephone pole!! Gosh you better be careful or you won't be around to tell us about it!! There are window defrosters you can buy I think. Watch where you're going!!!!
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Sat Jan 13, 2007 3:45 pm
im all sad the base removed the pole i hit. I guess ill have to make a little cross and put it where the pole was... :lol:
Anyway, i was playing the LUV and sliding around corners on some back roads on base, i honestly dont think i could loose controll in the LUV. I was even trying and it just took letting off the gas and I was good again...
