It is currently Fri Jun 19, 2026 6:01 am
 Post subject: Part numbers
PostPosted: Mon May 29, 2006 8:11 pm
I'm tired of trying to find parts that will work on my Luv's, so I'm writing down all part Numbers, and Manufacturing company that make them. It will be very helpful, if those parts are still available in the future, so I don't have to sound like a nobody, when I ask for parts. If you guys could help me with this project, provided I'm not stepping on anybody elses toes, and send me the parts numbers and manufactors when ever you buy a new part, I'll asimilate it into a parts list. I'll start, of course these numbers came out of the repair manual.
Spark plugs NGK BPR6ES
Ingnition Coil Nippon Denso C6R-207029700-3500
Distributor Nippon Dnso 0279100-32820
Voltage Regulator TL1287
Voltage Regulator MPA RE-1256
75-1256
Starter Hitachi S114-202
Oil Filter Purolator PFR-123 ????
Fuel Cap Federated 46166
condensor Niehoff WA230
That's all for now, be rest assured until I get my 80 going again, I'm sure there will be more numbers.
PostPosted: Thu Jun 15, 2006 6:36 pm
Did alot of that today, here's what I got so far:
Upper Radiator Hose:Goodyear 61253 or Napa NBH 7886>molded not flex
Lower Radiator Hose:Goodyear 60804 or Napa NBH 7554>molded not flex
Bypass Heater Hose :Goodyear 63025
Water Pump:Beck_Arnley 131-1299
Thermostat:Beck_Arnley 143-0699
Coolant Temp Sensor:GP Sorenson 385005
Haynes Manual:Haynes 24050
Radiator Cap:CST 7016
Fuel Filter:Beck_Arnley 043-0025
Points:Beck_Arnley 171-6992
Distributor Cap:Beck_Arnley 174-0802
Ignition Coil:Beck_Arnley 178-8025
Voltage Regulator:Wells UR743
Spark Plug Wireset:Beck_Arnley 175-4829
Distributor Rotor:Beck_Arnley 173-1413
Condensor:Beck_Arnley 172-1943
I think it would be cool to have a thread with a compilation of part #'s, good luck with it.....RF
PostPosted: Thu Jun 15, 2006 7:04 pm
Been doing lots of research, here's some more #'s
Weber Carb 32/36 DGEV:22680.033B (Webercarbsdirect.com)
Offenhauser Intake Manifold:OFY-6204-CW (Summittracing.com)
Oil Filter:Mobil M1-105 (Autozone or similar)
Cheers, RF
PostPosted: Thu Jun 15, 2006 8:06 pm
i have yet to have any trouble getting parts from Napa :?
 Post subject: part numbers
PostPosted: Thu Jun 15, 2006 9:01 pm
Thanks for you input, now I've got to get to work and get it all typed out somewhere and put it on a web page so everybody can read it. You don't mind do you? And yes, Dillon, you're one of the lucky ones, to be able to shop at Napa and find what you want. I usually have to return an item because it's the wrong piece, or etc.
1980 Chevy Luv 4x4 Mikado
the "Ole Man from Spokane"
