It is currently Sun Mar 22, 2026 7:39 am
 Post subject: fuel mileage
PostPosted: Wed Feb 15, 2006 9:46 pm
About what kind of mileage is everyone gettin with verious engines in your luvs?
PostPosted: Thu Feb 16, 2006 11:04 pm
With my 400 I get about 6 mpg cause I got 4.56 gears with 25'' tall tires.The stocker used to get about 12-16.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Feb 17, 2006 2:32 am
ive got a 1.8 in my pup and i can get 22mpg if im nice with it.
PostPosted: Sat Feb 18, 2006 12:06 am
I have a stock 80 4x4, it gets 26-27
PostPosted: Sat Feb 18, 2006 9:51 pm
I get about 25-33 depending if I use 4wd
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Mon Feb 27, 2006 3:14 pm
not exactly sure i will calculate
i get about 14-16 highway with my V8 and 350 trans
PostPosted: Mon Feb 27, 2006 7:26 pm
6-8 with my Buick odd fire 231, turbo 350 and stock rear end. Man I wish this site would have existed back when I built my truck. You guys dont know how lucky you have it, I had nobody to ask questions back then and trial and error sucks!! :evil: But I did have better access to parts back then! :twisted: Off topic rant related to the original question, sorry :oops:
PostPosted: Mon Feb 27, 2006 9:44 pm
Thats about me also. On days I keep my foot out of it :P
PostPosted: Wed Apr 26, 2006 9:40 pm
I get low to mid-20's city with both of my stock trucks after rebuilding the stock carbs.
PostPosted: Fri May 12, 2006 8:26 pm
I took a 120 mile road trip last weekend. It was the first long run with the reworked axle. After doing the math, i calculated that my 400SB/TH 350, 2.75 geared, 25" tire setup gets 15 m.p.g. on the Hwy. I gained about 4 more m.p.g. with the fixed up axle.
PostPosted: Fri May 12, 2006 9:34 pm
Small block, 4.56 gears with auto trans, 31 inch tires I get 8 or so.
PostPosted: Sat May 13, 2006 5:08 pm
My stock 4X4 gets about 25, but it needs a tune-up.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Sat May 13, 2006 6:14 pm
Banishment Pending
16-20, but I also have larger than stock tires, so I'm guessing 20-26 when figuring in the difference in tire size
PostPosted: Sat May 13, 2006 8:54 pm
I figured mine with the larger tires. I drive 110 miles a day to work and back, so I filled the truck up, drove to work and back and filled it up again.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Sat May 13, 2006 9:12 pm
How many gallons did it take to fill it back up?
PostPosted: Sat May 13, 2006 9:14 pm
It took 4.5 gallons.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Sat May 13, 2006 9:21 pm
It comes out to 24.444444444444444 miles per gal on the Hwy.
PostPosted: Sun May 14, 2006 12:33 pm
Picky, picky, picky.
1980 LUV Mikado 4X4
2003 Chevy S10
