It is currently Wed May 27, 2026 10:50 am
 Post subject: Harmonic damper question
PostPosted: Thu Jan 19, 2006 10:03 pm
SBC 283 and 327s are both internally balanced right? So the dampers can be interchanged I am guessing? I have a really small damper on my 283 that I pulled out of my truck and I want to put the small damper on my 327 if it will work.
PostPosted: Fri Jan 20, 2006 12:19 pm
You should be fine gabe, both the 283 and 327 are internaly balanced.. The 400 is the only stock one that isnt internaly balanced. The lighter the balancer the better normaly. Let me know if you need to borrow my puller or anything.
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
PostPosted: Fri Jan 20, 2006 8:49 pm
I went to card board freight today after work and got them both off tonight.
