It is currently Wed Mar 18, 2026 4:25 pm
 Post subject: Older gauge cluster
PostPosted: Mon Jul 25, 2005 1:10 am
I am new to this site and was wondering if an older luv gauge cluster like a 4 headlight one (Mikado) would fit in my 80 Luv 4x4. Please reply :?:
(sold) '79 2wd Luv
Current '80 4wd Luv(sold for $100)
Searching for one in Florida!
PostPosted: Tue Jul 26, 2005 12:06 pm
Physically fit, yes. Wiring should be pretty close but I'm not certain since I have never tried it myself. The speedo should even be pretty much the same as far as reading. They didn't change the trans when the gauge cluster changed, so the dial should behave the same. The fuel gauge may be a bit off, the sender is slightly different on the older trucks, but it is pretty close. Try for a cluster from a 76 or 77 and I think it will match as good as any. If the fuel gauge is to far off, you could swap sending units in the tank to match the gauges.
 Post subject: re
PostPosted: Fri Jul 29, 2005 4:36 am
(sold) '79 2wd Luv
