It is currently Wed Mar 18, 2026 10:07 am
PostPosted: Fri Jul 22, 2005 8:14 pm
My brothers got a 97 Mitsubushi Eclipse. On the front fender,
theres about a square inch where the paint got chipped off, but theres no dent, just some surface rust. We might end up taking it to a body shop so they can match the paint, but I thought about doing some of the prep work to same some money.
Can I just use some 240 grit sandpaper and sand the bare metal and feather where the paint meets up with the bare metal?
Any thoughts or ideas?
I am guessing it may be about 300 bucks if I just drop it off and say fix it.
PostPosted: Fri Jul 22, 2005 9:49 pm
You can feather the chip(s) with 240 grit, then spray the whole fender with high build primer. BLOCK wet sand with 400 grit then repeat until it is smoooooth :) . Should only take 2 coats if sanded properly. Good luck
Cement Shoes available here....One size fits all!
"Rum And Pepsi's Got Your Whole Perception Of Me Sketchy.....Cause When I Stage Dive, People Are Scared To Catch Me"
PostPosted: Sat Jul 23, 2005 4:44 pm
That makes sense, but would the body shop want to paint the entire fender? I would think if the paints not that old, they would just repaint a small area around the portion that has chipped off.
PostPosted: Sat Jul 23, 2005 4:48 pm
I think that would depend on the shop. I was assuming that you were removing the fender and taking just the fender to the shop.
PostPosted: Sat Jul 23, 2005 8:03 pm
Since there is not dent, I dont have to remove the fender. I'd just drop the car off there. I think I'm just going to hit the area with some 240
and then let the body shop do the rest.
Thanks for your input though. :D
