It is currently Sun Jun 14, 2026 12:49 am
PostPosted: Sun May 29, 2005 5:24 pm
Due to the all the stereo crap I am putting into my luv, I now need another battery. What is the best way to hook up and charge 2 batteries? I've seen it a couple of different ways but have no clue which is the best way.
PostPosted: Mon May 30, 2005 10:55 pm
do you have to have 2 batteries? maybe you could just get one good battery and get like a delco style alternator. like off of a bigger GM vehicle.
or you might try running the batteries in line. like one battery is gounded to the frame and then the positive from that battery goes to the negative of the other battery that then goes to the starter. then you could run the accesorys off of the first battery in the series and have the second battery in the series for starting the truck. but i think trying to charge 2 batteries with the stock alt will burn it up in a hurry which is why i said to get a better altenator. just my .02
neil
PostPosted: Tue May 31, 2005 2:32 am
You have two choices.
You can hook them in parallel, both grounded to the frame, and both positives hooked together. This will give you extra battery storage capacity. In other words, it would take you twice as long to run down your batteries. It would also take twice as long to charge them.
Or you can add a RV style isolator that will serve various functions. The isolators usually do things like charge both batteries with your alt, but will only run one battery dead for your stereo and let you keep the other one charged for starting the truck.
Do not hook them in series, battery 1 neg grounded, battery 1 pos going to battery 2 neg, battery 2 pos to electrical system. You will get 24V and fry most everything in your electrical system.
PostPosted: Tue May 31, 2005 3:14 am
oh! dont listen to me! i didnt know that it would make 24v. i figured it would be like a flashlight. im a motor guy. i always have a friend do all my complicated electrical stuff. my bad.
neil
PostPosted: Thu Jun 16, 2005 6:44 pm
I have a 16 volt alt. now and an Optima Red Top battery. What do you think, will that run my elec. water pump, fan, fuel pump, plus 3,200 watts of stereo?
PostPosted: Fri Jun 17, 2005 5:05 am
pretty sure it would, my duralast'll run my stereo and it's thumpin' twin jesen 6x9's 120w peak and it WAS running two little speakers buuuuttt.... i cranked it up two much and now one is blown and one is buzzing like there's a bee in my fender... in the process of finding some speakers that'll handel the bass i love so much.
Once I get a tonnue cover however i'm gonna get a sofa bed insert (see [url=http://www.truckperformance.com/products/searchtype_d/sortorder_DAA/productcategory_Sofa+Beds+~~+Accessories/category_Exterior+Accessories/sf1_ISUZU/sf2_1982/sf3_Pickup/sf4_Short+Bed/url]here[url])
that'll look nice with some sub's n' tweeters.[/url]
PostPosted: Fri Jun 17, 2005 5:15 am
off topic, but i seriously need to get a picture of the system in the pup. its SOOO funny. its got some stock kicker panel speakers, and then behind the seat theres 2 jensen 6x9s that have cardboard for boxes. funny stuff. ill get a pic later today.
neil
