It is currently Sun Jun 14, 2026 12:47 am
 Post subject: What was this?!?!?!?!
PostPosted: Tue May 10, 2005 9:10 am
What year and model was this chevy truck? Image
PostPosted: Tue May 10, 2005 9:38 am
I'm not 100% sure but it looks like a 70's half ton.
1980 Chevrolet LUV stock 1.8L longbed
1980 Chevrolet LUV parts truck shortbed
1983 Suzuki Gs550 Sportsman
1989 Nissan King cab P/u <totalled> 4/1/06
1986 Full size Chevy P/U
1993 Volvo 850 GTL
PostPosted: Tue May 10, 2005 9:45 am
73thru 78??
PostPosted: Tue May 10, 2005 11:57 am
anybody for sure? i kinda need to know what it is exactly.
PostPosted: Tue May 10, 2005 12:14 pm
73-78 chevys are so similar it is hard to tell. The grill, headlights, and mirrors look just like the 78 my parents bought new back in the day though. That pic also doen't show enough to tell a whole lot. For example, from that angle I couldn't say for sure if it is a 2wd or 4x4. That would give you a start on the model, K for 4x and C for 2x. It looks a little low to be a 4WD, but it could be sitting in a hole and the pic could be from a high angle.
1/2 ton would have less than 8 lug wheels, 3/4 or 1 tons will have 8 lugs.
A pic of the interior might help, though I am really rusty on that stuff so I don't know for sure how much it will help. If you can get that though, you should be able to get the VIN code and then we can just look it up.
PostPosted: Tue May 10, 2005 9:25 pm
The grill makes it a 73-74.
PostPosted: Wed May 11, 2005 10:01 pm
what year did they make them White ?? LOL :D :roll: :o
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Thu May 12, 2005 6:52 am
If you give me the VIN number than I can decode it for you.
1993 Volvo 850 GTL
PostPosted: Thu May 12, 2005 11:16 am
I didn't catch the differences in the grill at first. It does look earlier. Also, I believe the amber turn signal lenses point to an earlier truck, by 77 they were using clear lenses with amber bulbs.
It is hard to pin it down exactly though. I think I see a solid vinyl seat in there, so that might point to a lower end trim package. i.e. Not a Silverado with the nice cloth seat and shiny dash trim. Other than that, the picture just doesn't have quite enough info in it.
As 684 said, get the vin and we could tell you more about it than you'd want to know. There are several VIN decoder websites around that could give you year/model info along with engine/drivetrain data.
PostPosted: Wed May 18, 2005 11:53 pm
that grille whent up through 80 im prety shure. 1/2ton 2wd will have 5lugs and 4x4s will have 6lugs. The 3/4and 1tons will have 8lugs.
PostPosted: Mon Jun 06, 2005 9:07 pm
The round headlights indicate that it's got to be between 73 and 78. In 79 they started with the rectangle headlights.
