It is currently Sun Jun 14, 2026 12:48 am
 Post subject: Need a Ford Expert
PostPosted: Tue Apr 26, 2005 8:48 am
Ok, here I am on a Chevy site looking for some help with a Ford!!!! Anyway, I have a Ford nine inch rear end under my 1953 Ford F-100. It is 57 inches from flange to flange and has disk brakes. What I need to know is what vehicle this dang thing came out of! I need to rebuild the brake calipers and the prior owner hasn't responded to my e-mails for the last month. I am positive it is a nine inch and physically measured the read end last night. Does anyone have any idea what I can do to identify the parts I need to fix this thing? This afternoon when I sneak out of work, I mean after I get off of work, I plan to bring it to Pep Boys and have them take a look at it if I can't figure out what Parts I need or rear end this is. Thanks...
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Tue Apr 26, 2005 9:13 am
I've never had any luck with the big chain type auto parts stores when I need help like that. (if they can't look on the computer they're lost)
I would try to find a mom and pop parts store or even a speed shop in your area that would have knowledge in their head.
I was at LVMS last Friday night and Saw Shelby's shop in the buildings near the freeway. There is also some other shops in there. I would think somebody around there could help you out with advice if you just haul it up there and show them.
 Post subject: Rear End
PostPosted: Tue Apr 26, 2005 9:25 am
I didn't think about Shelby. I work close enough to their shop to smell their cars. I think I will pass by. Thanks.
Rick
Loranger, La
PostPosted: Tue Apr 26, 2005 10:28 am
Just a guess but it could be from an early Bronco
Cement Shoes available here....One size fits all!
"Rum And Pepsi's Got Your Whole Perception Of Me Sketchy.....Cause When I Stage Dive, People Are Scared To Catch Me"
PostPosted: Tue Apr 26, 2005 10:46 am
All the info you need to identify what axle you have is right here..
http://www.kevinstang.com/Ninecase.htm
:smt023
PostPosted: Tue Apr 26, 2005 4:18 pm
Japanese Redneck
does it have a smooth (with 2 dimples) back on the pumpkin or is it a later model 9 with the ridge for the ring gear?
57" with a ridge on the back of the pumpkin and factory disks would be a late model. probably a Lincon Versaille. i bet it has a 5 on 5" lug pattern too?
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Mon May 02, 2005 12:33 am
i was going to say it sounds like a licoln rear end. So i would run whith LUVSADRAG
