It is currently Sun Jun 14, 2026 12:59 am
 Post subject: deisel to gas?
PostPosted: Thu Apr 07, 2005 8:20 pm
Can anyone tell me how tough it would be to convert a deisel over to gas if it can be done at all?
PostPosted: Fri Apr 08, 2005 2:08 am
with still using the diesel motor? you could just put some super duper AV gas in it and see if it runs. ive seen oldsmobile diesel 350s converted to gas with an edel int and some 403 heads. dont know about the luv motor.
neil
PostPosted: Fri Apr 08, 2005 1:07 pm
Typical diesel motors have such high compression that its almost impossible get gas to behave right in them. There are a few exceptions, some old time tractor motors you'd start on gas then switch over to diesel or kerosene after they'd warmed up. I think GM had a diesel motor based on a SB 350 too, likely related/similar to the olds you mention farmerjoe.
Just converting a rig to run on a gas motor would be like any other motor swap. Maybe a few extra problems to fix but nothing really worse than your typical V8 swap.
