It is currently Thu Jul 02, 2026 7:41 am
 Post subject: NITROUS
PostPosted: Mon Jul 26, 2004 6:14 pm
Is there any easy way to hook up a nitrous system up to a truck with out haveing to replace every fuel injector? I have an 89 f-150 I'm wanting hook nitrous up to the passing gear so that when i'm hauling a load into the mountains that I can keep up with the traffic before the mountains and not get runned over. I really dont know how to do it but I have an idea , the people I have talked to at the local parts store they said i had to repace all the fuel injectors, I was wandering if their was a way to put them in the air intake? and if theres a web sight that has the cheeper brand than nos. any help is appreciated thanks josh
PostPosted: Mon Jul 26, 2004 9:11 pm
OG Lifer
You can get a single jet to plumb into your intake boot just after the maf before the throttle body. If you don't have a chip to give you more timing, I wouldn't do it. I also wouldn't use a dry kit, get a good wet kit (Zex makes a great little kit). But I would really advise against using nitrous at all for what you need. That is a dangerous thing to mess with for long periods of time. Such as climbing a mountain with a trailer full of stuff. That is just asking for big trouble. :wink:
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Mon Jul 26, 2004 9:37 pm
is there a way I can find out if my truck hasa limiter or if i can install a chip to give it more power? I know it has EFI but I dont know if it has a govoner or if it has to have a chip for its max out put. Is there a web sight so that i could find out?
PostPosted: Mon Jul 26, 2004 11:11 pm
OG Lifer
I believe your truck has a speed limiter built into the computer, set at 100 or a little higher. A good chip, ie superchips, or diablo should be able to clear that. A chip will also give you more power. A superchips tuner may give you more power than the chip.
