It is currently Wed Jul 01, 2026 8:43 am
 Post subject: lifting datsun
PostPosted: Sat Jun 05, 2004 1:15 pm
well he wanted to lift it like the musclecar look in the rear and jack it up
so i bought a pair of shackles instead of making them, well i started last
night never put lift shackles on before well i got as far as getting one side
done and that was it and it only gained bout an inch but that was at lowest
setting on the shackle the springs are pretty well flattend out almost
i am thinking of gettin a pair of springs with a couple more leafs
and then this shackle kit
its been a nightmare to try and lift this
PostPosted: Sat Jun 05, 2004 4:38 pm
the rule with shackles is that for every inch longer than stock the shackle is, you get 1/2 inch of lift
could always try adding a few leaves to each pack to make them stiffer
