It is currently Wed Jul 01, 2026 10:44 am
 Post subject: Chevy Astro Missing
PostPosted: Tue May 11, 2004 5:47 am
:?: My van sounds like its missing. I have replaced the cap, rotorbutton, plugs, wires, coil, and did a compression check. Anyone got any Ideas :?:
PostPosted: Tue May 11, 2004 8:33 am
You need to either clean the throttle body or the injectors. Depending on what year it is. I used to work at my brother-in laws shop and he had an account with Coke. They used Astros and we were always tuning them. I also have an Astro too.
PostPosted: Tue May 11, 2004 9:03 am
Its a 95
The spider injector crapped out about 6 months ago so its new and I clean the intake(upper and Lower) in the process. Any other Ideas... PLease
PostPosted: Tue May 11, 2004 6:10 pm
check good for a vacuum leak
GOTTA GET A NEW LUV!!!!!!!!!
