It is currently Tue Jun 09, 2026 2:26 pm
PostPosted: Mon Mar 29, 2004 4:45 pm
Are there 3 different brackets needed to install an alternator to a small block? The adjustment arm, The bracket that the alternator pivots on, and the bracket to mount it to the header bolts? This seems to be the setup that i've seen on most of the trucks in the gallery. If this is correct, is it a good assy? Oe should i try and find a better setup?
PostPosted: Mon Mar 29, 2004 8:47 pm
I jave found the one off of a 67-72 chevrolet truck works great!!
I have seen them on several trucks in the gallery and I have put them on several trucks I have done work on
GOTTA GET A NEW LUV!!!!!!!!!
