It is currently Wed Jul 01, 2026 12:54 pm
 Post subject: EFI Adjustment
PostPosted: Thu Mar 11, 2004 4:40 pm
I have an 87 toyota 4runner and it is running poorly. I have never messed with adjustments on fuel injection. Anybody know how???
PostPosted: Thu Mar 11, 2004 8:14 pm
what exactly is it doing? i'm a big toyota guy but i've never owned anything with a 22RE in it...you might want to check http://www.yotatech.com
PostPosted: Thu Mar 11, 2004 8:46 pm
well my troppers 2.6l was running rough and i got the timing in spec and it smoothed right out. Might be the same whith yours, try it.
PostPosted: Fri Mar 12, 2004 11:37 pm
probably dirty injectors, pull them out and have them cleaned/checked.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Wed Jun 23, 2004 11:39 am
check you're fuel pressure, ignition components, fuel filter, vacuume leaks, and idle speed screw on the side of the throttle body. remove the screw and clean the carbon deposit off of it. these are neglected quite a bit and can cause idle problems
