It is currently Mon Jun 08, 2026 6:48 pm
 Post subject: Timing cover?
PostPosted: Wed Nov 26, 2003 11:43 am
I was wondering if anyone knew if it is possible if you can pull the timing cover and put it back on without having to drop down the oil pan on a small block chevy. I have heard some people say that you can clip the little tabs behind the seal on the side and should be able to slide it in.
PostPosted: Wed Nov 26, 2003 12:23 pm
Yes, you can pull the timing cover without dropping the pan. Done it many times myself. Don't forget to remove the two 5/16 pan bolts. Also, you should use a little RTV where the two seal tabs are. I can't remember if I had to cut those tabs off or not.
