It is currently Fri May 22, 2026 12:36 pm
 Post subject: Has anyone!?
PostPosted: Fri Dec 19, 2014 3:38 pm
Has anyone used chevy luv chassis for a hot rod build? if so post the pics or links below. I just acquired a junk luv and want to use the frame and components for a 32 ford.
1980 Chevy LUV 4x4 Weberfied Sold
1974 Chevy LUV 4x4 Weberfied
 Post subject: Re: Has anyone!?
PostPosted: Fri Dec 19, 2014 5:21 pm
I have seen a couple 32 ford bodies on Luv frames and they fit pretty well. One had the horns welded on the front of the frame to look more like 32 frame rails. Luv suspension isn't as nice looking as the typical roadster though. 8)
PostPosted: Fri Dec 19, 2014 10:25 pm
Even though the LUV frame is solid and strong I personally wouldn't use it for a 32 build. There are so many other options out there. With the LUV setup you would have torsion bars and I like the straight axle set up like the traditional 32.
