It is currently Fri May 22, 2026 3:03 pm
 Post subject: I need help
PostPosted: Sun Jan 11, 2015 5:19 pm
So i took my valve cover off my Luv to change my gasket and i decided to paint the valve cover from the outside, BUT some paint went on the inside of the valve cover, is that a problem? Can it mess with the oil once i install it back? Or it doesnt really matter? I really need help on this, thanks
 Post subject: Re: I need help
PostPosted: Sun Jan 11, 2015 8:34 pm
I wouldnt worry about it unless it is loose. Hit it with a wire brush and wipe it down with acetone and your good.
PostPosted: Sun Jan 11, 2015 8:44 pm
fuhgeddaboudit. You are not the first and won't be the last.
