It is currently Sat Jul 11, 2026 11:16 pm
PostPosted: Sat Apr 06, 2013 4:39 pm
I've been trying to figure out how to get these out without destroying them, they are glued in with dum dum or something. I want to get them out in one piece to avoid paying $180 for factory and about $140 for aftermarket replacements :evil: the junkyard up the road has tons of camrys. I'm going to shoot some heat at em and see if that helps, but so far they won't budge. Any help is appreciated
1980 LUV 4wd 1.8, 31's, 3" body lift, weber 32/36, header, fakemaster, project in progress
1989 Isuzu Pickup 4wd 2.6, 2.3 head, weber 38, header, flowmaster, 31's, DD/light wheeler
1989 Camry, the race car
1968 Ford Fairlane Fastback, next in line
PostPosted: Sat Apr 06, 2013 7:57 pm
Have you looked at them from inside the trunk? I would guess there are a couple bolts from the back. Also that should be how you get to the bulb if that's what you're trying to do.
PostPosted: Sat Apr 06, 2013 8:33 pm
There's three nuts. They are glued in though. There's a hole in the outer cover and it's leaking water through the panel the bulbs plug into. The hole is too big to glue, otherwise I would :x
Users browsing this forum: Baidu [Spider] and 17 guests
