It is currently Tue Apr 23, 2024 3:45 pm
PostPosted: Tue Feb 12, 2013 7:51 pm
Hello All
I wanted to know if you can adjust the valves on the rocker arm and the valve or do have to adjust off the cam and the back of the rocker arm as the manuel speaks of. To my way of thinking it would not make a big differnce or is a differnt setting you would use.
thank you all
PostPosted: Tue Feb 12, 2013 10:08 pm
I would like to help you friend but I'm unclear about your question. Roll the engine until the back of the cam lobe (the low part) is centered under the cam follower. (The manual says 1 and 4 at TDC but hell you can see the cam right there) adjust the valve with a feeler gauge between the rocker arm and valve. Make sure that the engine is dead cold. ( if you can, do it before you start it for the day.) intake .006 exhaust .010 Easy cheesy.
I hope that was helpful because I really didn't understand your question.
PostPosted: Wed Feb 13, 2013 7:23 pm
Thanks you answered my questions.
PostPosted: Wed Feb 13, 2013 10:55 pm
Great! glad that I could help Sir.
