It is currently Sun Jul 12, 2026 7:37 am
 Post subject: 4.3.. mini mouse?
PostPosted: Fri Dec 30, 2011 3:25 pm
well the thought came to mind yesterday... if the small block is the mouse motor does that make the 4.3 at 3/4 of a 350 a mini mouse :eugeek
mini mouse muscle mini truck :lol:
 Post subject: Re: 4.3.. mini mouse?
PostPosted: Fri Jan 06, 2012 8:08 pm
The chevy 4.3 V-6 was a great motor with few problems.
I think it would fit right in to a Luv.
That would be a sweet ride!
PostPosted: Fri Jan 06, 2012 11:20 pm
picking mine up with 700r4 tomorrow around noon so im hoping it will be sweet :lol:
i know a few people have made the swap recently or are in the process. stock @ 235LbFt should be a lot more exciting off the start at the least
so Mini Mouse?
PostPosted: Fri Jan 06, 2012 11:46 pm
A mini mouse to me is any small block with less than 350 cubes...
V6 and 4 cylinders are just in the way in the engine bay, lol...
PostPosted: Sat Jan 07, 2012 2:00 am
meh... more cubes than the 4 banger
its.... about 2.4x the displacement. plenty for my needs :lol: its my daily and my toy a 4.3 can do both to my liking.. i don't have a lot of straight lines out here to go shoot my luv down... lots of windy mountain roads tho... and the last ting i want is a crapload of weight up front on constantly wet twisty roads :lol:
well picking up my motor is about twelve hours so i will have an update on my build as soon as im home
PostPosted: Sat Jan 07, 2012 8:03 pm
4.3 would be a Hamster short of tail big of heart. LOL
PostPosted: Sat Jan 07, 2012 9:10 pm
THis... :lol:
PostPosted: Sun Jan 08, 2012 2:43 am
HA ok that is great :lol:
PostPosted: Tue Jan 17, 2012 11:48 pm
You can get a lot of power from that 4.3L Uses most of the same tricks as SB and there are a lot of parts for it. It's weight is closer to the stock, get it set back correctly and you will have a neat handling truck. Use a 700r4 get the tallest gears you can put in the stock rear end. 3.06 trans first gear with 0.8x overdrive. Would make an excellant truck to pull your trailer with your race LUV. Bolt in mounts and headers, make it a long weekend swap.
PostPosted: Wed Jan 18, 2012 1:12 pm
got a 700r4 with it sitting in my garage waiting for me to get paid again so i can get the 4 bbl intake and a q-jet along with an hei dizzy and i will be in business :lol:
found intake for $50 a few q-jets for 25 a piece, gonna have a buddy of mine who races rebuild and jet one for me. looking for the original hei dizzy for the early 4.3 and im set to go
30% OD will make things a lot more fun at freeway speed.. and i will be able to pass without putting my foot thru the floor for once :roll:
PostPosted: Mon Dec 17, 2012 4:51 pm
I loved mine. And it would run 13.90's in the 1/4 all night long. The down side, I was turning 6900 rpm's at the finish line. TH350 and 4.56 didn't go good together, but I LOVED it! When I would shift to 2nd the rear tire's would break loose. This was before the Vortec heads too.
PostPosted: Wed Dec 19, 2012 8:33 am
1073 hp 4.3l V6 .
http://youtu.be/Q5ej6SPKk3w
PostPosted: Wed Dec 19, 2012 3:12 pm
We have a local bracket racer with a Chevette that has the voertec headed version . It makes good power . He was high enough in points to get into the divisionals and the car fix no-e street class . He ended up winning no-e street and going to Pamona for nationals . Strong runner , no the fastest , but strong .
PostPosted: Wed Dec 19, 2012 8:39 pm
mine is still sitting in pieces on my work bench. been waiting for the new year to get started when i get my tax return, picked up a second job so will be saving up to build it right
going to get rid of the stock heads and buy a set of '96 vortec heads, a 2114 intake and a 4 barrel.
looking into a 4x4 t5 and some 31's to go with it.
