It is currently Sat Mar 21, 2026 12:14 pm
PostPosted: Sun Sep 11, 2011 10:03 pm
I went to the junkyard today, and found two disc brake generation LUV's.
I'd really like to make that my first improvement to my new (to me) '75.
Is it just the four bolts at the bottom?
Also, what's the easiest way to free the top? Difficult to separate the ball joint from the hub, and the nut above it is HUGE.
I'm going back, in the morning, and I'd like to be armed for what needs to happen.
Thanks in advance.
PostPosted: Sun Sep 11, 2011 11:41 pm
http://www.luvtruck.com/Information/Brake_swap.htm
And yes, the ball joint will likely put up a fight unless it's been replaced. While your there, you may want to grab an extra set of castle nuts.
PostPosted: Mon Sep 12, 2011 12:06 am
Alright...I'll just keep at it.
I'm quickly discovering how cheap the hardware is...might get anal and replace with nice stuff at Fastenal.
That ball joint is a real pain.
