It is currently Fri Mar 20, 2026 3:44 am
PostPosted: Tue Dec 07, 2010 9:37 pm
I have been working on a 96 Geo Tracker and finally about got it finished. The EGR valve has an exhaust leak and after looking at it closer the part of the valve that faces the head has a hole. Should there be some kind of plug in the hole? I have tried looking online and can't find a good picture anywhere. Thanks.
PostPosted: Thu Dec 16, 2010 11:22 am
is it a 4 port EGR or 2 port?
PostPosted: Thu Dec 16, 2010 6:42 pm
It has 2 vacuum hoses going to it. I think I got it fixed. I went to Carquest the other day and got a frost plug. Got it put in this morning. See what happens now.
PostPosted: Wed Feb 16, 2011 11:57 pm
must be a 8V 1.6L :?:
cause my 16V 1.6L EFI has no EGR
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Thu Feb 17, 2011 7:17 am
it is the 1.6L 16 valve. the egr is located on the rear side of the intake and sorta under it.
PostPosted: Thu Feb 17, 2011 2:33 pm
waaaa :?:
what year is it?
mine are 1992 and 1993
86trooperT/D 2.2
PostPosted: Mon Feb 21, 2011 6:53 am
If I remember correctly it is a '96.
