It is currently Thu Apr 18, 2024 11:22 pm
 Post subject: Rear Axle Bearings
PostPosted: Tue Aug 24, 2010 2:24 pm
On a '79 FWD do the bearings need to be packed with grease like the front wheel bearings?
 Post subject: Re: Rear Axle Bearings
PostPosted: Tue Aug 24, 2010 2:44 pm
No, the oil in the diff lubes them as well
PostPosted: Tue Aug 24, 2010 2:55 pm
Australian LUV Guru
The bearings need to be packed with grease, there is an oil seal in the axel tube that keeps diff oil separate from bearings. I have read posts on isuzupup.com of people fitting grease zerks to prolong bearing life.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sun Oct 17, 2010 10:38 am
The bearings do need to be packed with grease, and there is an oil seal in the axel tube that keeps the diff oil separate from bearings.
If you go to my post Bulding a daily driver here at viewtopic.php?f=33&t=22285 you will see how I removed the bearing, and the tool I made to do the job.
