It is currently Wed Mar 18, 2026 10:32 am
PostPosted: Thu May 27, 2010 12:56 pm
i have a 76 monte carlo with a 350 i need 2 put a catylitic converter on it to pass cali smog, i have a converter from a 4 cyl i think late 80s or maby early 90s volvo so my question is can i use the volvo converter on my monte and do you thinkit will pass smog ?
any help is apriciated thanks
john
currently working on my 1977 luv truk
PostPosted: Thu May 27, 2010 7:54 pm
Nope the converter you have is to small and will choke the motor you need one for your size motor or a little bigger. But beware as a muffler shop can not weld in a used converter legally.If you want to try and get by with a used one try and find a later model one as they are less restrictive and smaller. Happy welding.
PostPosted: Thu May 27, 2010 8:53 pm
autozone a universal ones for $75 if that helps
PostPosted: Fri May 28, 2010 6:55 am
ok cool thanks. i can weld it my self so no worrys if i get a used one. thanks for the info.
Users browsing this forum: Google [Bot] and 13 guests
