It is currently Fri Apr 19, 2024 7:11 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sun Oct 24, 2010 3:11 pm
yeah. sorry it's been crazy for a while.
the lights work now, but for some reason, the left turn signal doesnt want to work properly. it may just be a bad ground somewhere, but i have not had a chance to really do anything about it. besides, i only really use the trailer to tow scrap every once in a while.
if you need info, the easiest way of doing an install of a trailer light harness is to probe the rear tail light wires with a test light. (use a non powered one)
then as you probe the wires for turn, light, brakes etc. you will see what wire is which, and you can mark them. (the test light with flash in conjuction with the turn signals/hazards)
