It is currently Wed Mar 18, 2026 2:09 am
 Post subject: Electric fan
PostPosted: Thu Sep 17, 2009 6:18 pm
Well found out my flex a lite fan is a puller and not pusher even when the motor is reversed it doesn't blow enough air. How many cfm's would be best for my motor. They make the dual 432 that is 2500. Think that is too much. They are expensive as heck.
I have the puller that pulls 2800. It does blow a sheet of paper on the inside of the radiator when the motor is reversed. Could be my cooling problem more than likely.
 Post subject: Re: Electric fan
PostPosted: Thu Sep 17, 2009 8:47 pm
Can you flip the fan over? Mine was a reversible motor but actually spun faster one direction than the other..I flipped the fan over....
PostPosted: Fri Sep 18, 2009 4:27 am
I tried to get the blades off but it won't come off the shaft. It also has a spacer that is molded into the blade that goes on the motor one way. Don't want to ruin the blades and housing though.
I'll take a look again today.
