It is currently Wed Mar 18, 2026 6:47 am
 Post subject: E 85
PostPosted: Thu Sep 17, 2009 12:29 pm
Hey I was wondering if any one would know if my 383 stoker motor would run beter with e 85 it being 105 octane
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
 Post subject: Re: E 85
PostPosted: Thu Sep 17, 2009 2:50 pm
Esplain stoker
PostPosted: Thu Sep 17, 2009 5:09 pm
stroker i mean
its bord out to a 383 a mild cam high rise intake headers
79 4x4 1.8 liter
PostPosted: Mon Sep 21, 2009 10:52 am
it probably would.
but if your asking this question, i dont reckon your ready for the tuning involved with using E85 for max power.
A.j.
PostPosted: Mon Sep 21, 2009 9:17 pm
If it is street driven, then it is all or nothing, you just can not fill up on one and then the other... Moving to E85 will require staying with E85 after that. You can not flip flop back and forth with out making more changes than most of use would do. Carb, timing to say the least. Not a problem if you have E85 around you. I know a few drag racers that have changed their race cars to run on E85... Cheaper than race gas, but it takes time to get it tuned right.
PostPosted: Tue Sep 22, 2009 12:23 am
Tuning is a must. I will also need to deliver more fuel i.e. bigger injectors, fuel pump.....
PostPosted: Wed Sep 23, 2009 11:09 am
well I ran about 8 ga in just to see and it ran smoth is stalled a lil if i just taped the gas but talk about the difrance in top end
79 4x4 1.8 liter
PostPosted: Wed Sep 23, 2009 11:17 am
here it is
79 4x4 1.8 liter
PostPosted: Sat Sep 26, 2009 8:21 pm
Throttle body injection will only require 2 different injectors. I am not sure about your fuel lines or how the computer will make up for the e85 fuel... Maybe the larger injectors will do it.
Unless you have a carb :wink:
Check these 2 links
http://www.raceone85.com/
http://www.e85performance.net/forums/index.php
