It is currently Wed Mar 18, 2026 10:33 am
 Post subject: stock gauges
PostPosted: Wed Jan 13, 2010 5:22 pm
has anyone who has done a v8 swap used the stock gauge cluster?
i am wanting to keep my truck as original as possible less of course the v8 and air-ride. i am wondering if i can use the stock gauges with the v8 swap.
:smt102
 Post subject: Re: stock gauges
PostPosted: Wed Jan 13, 2010 7:24 pm
Dont see why you cant. You will need the factory sending unit for the stock tank. The temp is electrical and the oil is a light. You might have to play with the speedo gear to get it to read correctly.
PostPosted: Wed Jan 13, 2010 7:30 pm
...what if ill be using a fuel cell?
PostPosted: Fri Jan 15, 2010 5:53 pm
It just has to have the correct ohm sender.
PostPosted: Fri Jan 15, 2010 6:11 pm
so with some time and such its entirely possible to keep the stock cluster for a v8 swap and have it fully functional?
PostPosted: Fri Jan 15, 2010 6:19 pm
yes. Someone here can tell you more about the stock senders.
PostPosted: Fri Jan 15, 2010 6:27 pm
ill look more into it when the time comes. being broke gives me a lot more time to plan and figure out what i really want to do. and keeping it stock as humanly possible is the big thing im focusing on
PostPosted: Fri Jan 15, 2010 10:35 pm
Why the fuel cell? I removed mine from stock location had all but one vent line plugged and welded in a 1/2 female pipe fitting. I then mounted it behind the axle, turned it sideways and filled it through the bed. Just extend the wire. Worked GREAT. Eventually went to a fuel cell only because my stock tank rusted a hole through.
PostPosted: Fri Jan 15, 2010 11:58 pm
I have a V-8 and a V-6 LUV with stock and complete functioning clusters.
PostPosted: Sat Jan 16, 2010 12:05 am
very good to know. thank you sir
im going to do air ride for starters. and my tank has a huge dent in it on top of being very dirty and nasty inside. instead of spending the time cleaning and fixing the stock tank im gonna get an RCI fuel cell to put between the frame rails along with my air tank behind the axle
Users browsing this forum: Google [Bot] and 13 guests
