It is currently Wed Mar 18, 2026 2:17 am
 Post subject: nissan pickup
PostPosted: Sun Jul 12, 2009 4:28 pm
so i might be getting a 1984 nissan pickup, it has the king cab or wat ever they call them, with the 2 seats in back too, it is only 2wd, so i cam lower it, and other things.... i am still working on my d50, and the LUV...... havent been on here in a while so i thought id stop by and jus say hi to every one i used to talk to! im guna come back on here again more!
add me on face book and my space if you have it!
http://www.facebook.com/profile.php?id=507727162&v=feed&story_fbid=108161412162#/profile.php?id=1022627806&ref=profile
http://home.myspace.com/index.cfm?fuseaction=user
 Post subject: Re: nissan pickup
PostPosted: Mon Jul 13, 2009 5:53 am
i had a 1985 nissan x cab 2 wd fun truck, however it is alot like the luvs in the fact that there are almost no parts available for it, after 350,000 miles ish the engine gave out found a new one put it in got a header and a weber on that little z24 engine went pretty good, blew a rear brake line and as i was crawling under it to check it out, i grabbed the frame to adjust myself and it crumbled in my hand, of course this could be because i lived on an island in s.e. alaska{extreme amount of salt in the air} :esad
anyway if that hadn't happened i would still have the truck, one of my fav's
anyway, long story but the jist is i just thought i would let ya know to check the frame especially from just behind the cab to the rear bumper
good luck with the truck and dont forget pics :wink:
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Mon Jul 13, 2009 9:41 pm
well i got the truck today, its got the z motor!!!
it has torsion bars up front, but it doesnt look like i
can back them off anymore, but every one else has
lowered theirs like that..... do they adjust them from
the back? im jus going to monoleaf it in the back........
oh and i need a carrier bearing!!! there isnt one there,
its almost like there was never one!
and i only have brakes on the one front wheel!
so i got the truck for 200 bux, and i need brakes and
a carrier bearing and its good to go! oh and i need a diff exhaust! :)
PostPosted: Mon Jul 20, 2009 1:29 pm
Lots of PB Blaster or another penetrating oil.. Use the PB Blaster and a BFH first. The torch is the last try. You could use a torch to help break free the rust. The torsion bar is tempered steel, so be careful of heating it. Heat the part that the bar fits into, not the bar. Get someone to help with heating it.
PostPosted: Tue Jul 28, 2009 1:20 pm
so it needs a lil work! haha but i jus couldnt pass a good running minitruck
like this for 200 bux!!! haha i lowered it about 5 inches in front and about 3
inches in the back, and my driveway is at an angle, and it ripped the stock exhaust
off, so i had to clamp that glass pack on and start parking it on the street........
until i get the money to go get a new one custom made.. sounds like a ricer now.. :(
so im guna get a roll pan, and a header with 2 1/2 piping into a magnaflow
muffler right where the spare tire would be, then into dual exhaust out the back with
some little exhaust tips...... hoppefuly it doesnt sound too ricey, but i hope
its deep with a good growl!!
PostPosted: Mon Aug 03, 2009 3:27 pm
A lot of the rice sound is in the exhaust tip that is used. No way to hide the 4 cyl engine sound.
