It is currently Wed Mar 18, 2026 12:45 pm
 Post subject: Turbo 400 ?
PostPosted: Sat Apr 11, 2009 8:35 am
I have a turbo 400 in my Chevy dually. I am changing the filter and when I was removing the fliter I noticed it wasn't tight but the hold down bolt was. I have not see the filter loose so am wondering if this is correct? There is a spacer between the filter and valve body but it is like the spacer is too short. Anybody have any ideas? Also I am installing a deep pan, do I have to lower the fliter or does it stay in the stock position? Thanks in advance for any help.
Joe
 Post subject: Re: Turbo 400 ?
PostPosted: Sat Apr 11, 2009 9:00 am
The filter in the TH 400 just floats in there as there is an O-ring on the case end and the bolt holding it in place. As for the deep pan generally they come with an extension to lower the filter.
PostPosted: Sat Apr 11, 2009 9:44 am
Thanks tj, I got the pan used from a buddy and he didn't have the extension. Maybe I should just go with the original pan.
PostPosted: Mon Apr 13, 2009 5:43 pm
Check your local GM / Chevy truck dealer, I believe they have the extender and O rings for the deep pan.
PostPosted: Mon Apr 13, 2009 7:33 pm
I'll do that. I live right next door to a Chevy dealer. The who is doing my tranny out of the race truck may have one, but if that falls through I will check next door. Thanks.
