It is currently Sun Feb 01, 2026 2:28 pm
 Post subject: Brake Trouble
PostPosted: Fri Feb 06, 2009 9:43 pm
Hey I just joined the forum. I have a 1981 luv and am having a little trouble bleeding the brakes. I had to replace the rear end so that is why i am bleeding brakes. Pedal goes to floor on the first try, it will pump up but if you let it set for few minuetes it will go to floor again when pedal is pushed. Any help with this problem would be nice.
 Post subject: Re: Brake Trouble
PostPosted: Fri Feb 06, 2009 10:04 pm
Could be a bad wheel cylinder in the new rear end..... Could be a bad master cylinder.
PostPosted: Fri Feb 06, 2009 11:52 pm
Are they adjusted correctly?
PostPosted: Sat Feb 07, 2009 9:11 am
It sounds like a bad master cylinder.
PostPosted: Sat Feb 07, 2009 10:00 am
:signiagree !!!!!
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Sat Feb 07, 2009 11:31 am
Bad master cylinder. The brake fluid is leaking past the seals back into the fluid reservoir. :(
PostPosted: Sun Feb 08, 2009 9:22 am
it has a new master cylinder, will make sure they are adjusted correctly today, also new wheel cylinders on both sides. New master did not come with new rubber seals on bottom of plastic resivor.
