It is currently Tue Apr 16, 2024 1:05 pm
 Post subject: isuzu heads
PostPosted: Mon Jun 02, 2008 10:21 am
I am interested in getting a twin cam engine for my luv... somethign that i also found is that you can take a 2.2 or 2.5l chrysler engien block and put a 2.0 or 2.4l engine head on it only having to change the oil ports (they dont line up right) and the cam gear needs to be a custom jobby so the teeth line up, have the corect count and shape... now somehting that i was wondering is that the way they found that this can work is that a guy happened to toss a 2.2l head gasket ontop of a 2.4l head gasket noticed that the bolts and cy,inders lined up and the rest was histoory... i was jsut wondering if anyone knew of a similar enomily between the G series ports and any, and i mena ANY other heads... i plan on doing some searching and trying to find somethign out and hopefully find somethign that will work, for what i plan on doing, it would be exclusively unique (for now) and i woudnt have to look for an engien from japan that dosen t seem to exhist...
thanks
-Dustin
 Post subject: Re: isuzu heads
PostPosted: Sun Jun 08, 2008 12:07 am
so... anyone at all? still curious
PostPosted: Tue Jun 17, 2008 11:09 am
i dont wanna get in trouble... im just bumping it...
PostPosted: Tue Apr 07, 2009 2:27 am
hopefully i can go to a parts store and they will let me look at a couple gaskets of isuzu engines and luv engine too see if there is any similarities... I'll let you all know of the results
PostPosted: Tue Apr 07, 2009 4:13 am
There is an Isuzu DOHC G-series 1600W/1800W/200W that was optional in RWD Japanese Geminis.
A few made it to AU & NZ.
Totally different from the 1.9/G200Z but if you wanna pay shipping you could probly source 1.
Try elky or Poida
http://workshopmanual.org/twincam/
_________________________
83 Isuzu I-Mark 1.8
01 Saturn L300 V6
PostPosted: Tue Apr 07, 2009 8:10 pm
i read somewhere that the blocks are eevn different, even thought the engine code is the same
