It is currently Wed Mar 18, 2026 11:45 am
 Post subject: posi rear end Q's
PostPosted: Thu Mar 20, 2008 3:43 pm
how do you make a rear end a posi rear end?
i have a rear end out of a 1985 olds cutlass and i dont exactly know what it is but it has 10 bolts ho9lding on the gears cover... i dont know if that matters tho.
but how would i go as makin it posi? i've heard of welding the spider gears but i dont see how that would make any sence :?
if any one has an easy way to do it or can show pics on how to weld it would be appreciated!
 Post subject: Re: posi rear end Q's
PostPosted: Thu Mar 20, 2008 6:35 pm
google up lincoln locker! I don't know much either but that's what it is known as hope that helps
PostPosted: Thu Mar 20, 2008 6:44 pm
if you were to do this I believe arc welding would be your best bet for strength of course using appropriate rod which you could ask a welding shop I m not really familiar with the different types or arc rod I know 6011 6013 7018 thats about the only arc rod I used anyway.
PostPosted: Sun Mar 23, 2008 6:56 pm
You could also get a mini spool.
PostPosted: Fri Apr 04, 2008 1:43 pm
If you are planning to drive the car on the street I would highly advise against a lincoln locker or a spool of any kind for saftey reasons. My C-10 has a detroit locker in it and even that gets scary at times. I would suggest something like a limited slip in a 10 bolt. What are your expectations in the car?
