It is currently Wed Mar 18, 2026 6:06 pm
 Post subject: fuel cell
PostPosted: Wed Feb 27, 2008 12:32 pm
is this ready to put in? or does it need any thing?
sorry i dont know much about them, maybe one of you race guys can hepl out? i needed to remove mine from under, no room and wanted it in the box!
so what is it about the foam? do you really need the foam? does this one need new?
http://cgi.ebay.com/ebaymotors/16-Gal-RCI-fuel-cell_W0QQitemZ130201121482QQcmdZViewItem?hash=item130201121482
 Post subject: Re: fuel cell
PostPosted: Wed Feb 27, 2008 9:15 pm
That looks like the one I have and it works well. The foam is probably inside the tank but check the part numbers. All the foam does is keep the fuel from sloshing around when you have less than about half tank. :D
PostPosted: Sun Mar 02, 2008 8:18 am
Did ya get it? I have one like it but mine is only 5 gal. Works good. The only problem I had is that it leaks fuel around the fuel fittings. I have tried new nylon washers and that helped for a while.
PostPosted: Sun Mar 02, 2008 9:40 pm
no i got to pay for the motor to be rebuilt for the luv first, and my suburbans motor threw a rod... so i have a few other things to do first
PostPosted: Sun Mar 02, 2008 9:43 pm
Sounds like you will be busy for a while.
PostPosted: Mon Mar 03, 2008 8:33 am
yeah :!: :evil:
