It is currently Wed Mar 18, 2026 2:01 pm
 Post subject: bent valves
PostPosted: Sat Nov 03, 2007 8:39 pm
Scored a set of heads tonight they are suppose to have bent valves. Can I buy new valves and install them or do they have to go to a machine shop first?
PostPosted: Sat Nov 03, 2007 10:19 pm
It's doubtful the valve angles will be the same. I'd take 'em in...
PostPosted: Sun Nov 04, 2007 11:49 am
A good valve job will enhance flow .
PostPosted: Mon Nov 05, 2007 7:59 pm
if your doing the seats and the valves..then just lap them and see where they are at.
I have a good head BTW...
Im not sure which specific engine it is.
PostPosted: Wed Nov 07, 2007 6:10 pm
well the heads are at the machine shop now I was told the valves are not 2.05s they are actually 2.02s. they were .100 longer than stock and ended up that 9 valves totall were bent. The guy working on them told me that there isnt a reason they needed to be longer and price wise it would be cheaper to run the stock length valves and get all new ones rather than buy 9 to replace the longer ones. Good thing I took them in because the heads were used on a 400 and the steam holes were jacked up and would have caused problems not to mention I didnt catch the dent left in the one cylinder where the piston slammed into it. I just got off the phone with the machinist and now he is telling me that the springs I have are too big for the way it was previously cut so now its going to need a new set of springs and they have also been milled so much that I have to have my intake manifold milled to fit.
PostPosted: Wed Nov 07, 2007 6:20 pm
The valves are usually longer to prevent coil bind on the springs when running a large lift cam. New springs to match the cam and new valves are a good idea. Looks like you'll have a fresh set of heads for at least half price...
PostPosted: Wed Nov 07, 2007 6:54 pm
cant you use a thicker head gasket to offset the milling so you dont have to mill your intake manifold?
I guess if it were milled an extreme amount it wouldnt matter how thick the gaskets were.
PostPosted: Wed Nov 07, 2007 7:48 pm
These heads orignally were used on a circle track motor where the rules at the time stated you had to use a cast iron factory head so I think what happened was they milled the crap out of them to get more compression and on top of that I have had to have them milled too so I am guessing from what the machine man told me that the intake manifold will need to be hacked up too. I dont know how good the cast iron summit brand heads are but I can say I could have bought a pair of those and some other parts for the money I now have into these Im kinda thinking I spent too much on on what I will be getting in the long run. Maybe Im wrong I dont know. The machinist is a friend of my brothers who said he is only charging me half price for this and that and throwing in parts for his cost he claims ,so I am hoping with my limited amount of experiance dealing with this sort of thing Im not actually getting raped.
PostPosted: Thu Nov 08, 2007 7:36 pm
Picked up the heads from the machine shop today they are all ready to go now. They are good to about .570 lift he said. not like I will be going that big anyway but at last they are done.
