It is currently Sun Mar 22, 2026 6:48 pm
 Post subject: battery junk?
PostPosted: Mon Apr 14, 2003 7:53 am
When I tried to start my truck yesterday it wouldnt even turn over. Put the charger on it for a few hours and still nothing. Tried to jump start it, still nothing. Could the battery be so dead that it wouldnt even jump start?
PostPosted: Mon Apr 14, 2003 11:27 am
Yes. It can die with no warning at all. How old is the battery? Did you clean the battery terminals? Do you have a good ground to the battery? Have you taken a voltage reading? Do your headlights work? Maybe the starter solenoid failed. It could be a number of things that would indicate a dead battery. If the battery failed, you should go thru the cables and check the system over to correct any condition that led to the failure.
PostPosted: Wed May 24, 2006 1:47 pm
Did you check the baterry water level? Also it could be the starter or the alternator.
PostPosted: Wed May 24, 2006 5:41 pm
How old is the battery? What is the resting voltage? When was the last time you started the truck, if a battery sits below a certain voltage ( Usually 10 volts ) it will lose it's " Memory " it will than only take so much of a charge and will not maintain the needed 12.6 Volts.
We need more info to help you better.
'76 MUD project, 1 ton axles, lockers, 20" Lift, Big Smallblock, On board air, 54" Boggers, Hummer Double beadlocks, External Rollcage... in the works.
PostPosted: Thu May 25, 2006 5:39 am
Judging by the original post date.. I'd say the battery is AT LEAST THREE YEARS OLD...
:lol:
PostPosted: Thu May 25, 2006 7:59 am
BigHappy could have replaced the battery and have it go bad by now.
PostPosted: Thu May 25, 2006 10:47 am
Japanese Redneck
HAHAHAHAHA DAMN that has to win some sort of award for oldest post revived.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Thu May 25, 2006 3:12 pm
Toyota Man can you please not bring back such old posts. The person has more than likely fixed there problem or no longer cares.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu May 25, 2006 7:17 pm
Ya please don't cause now I look like a JackASS :roll: , Not hard to do, I just saw a new post and didn't think to check the original date.
Sorry All :D
