It is currently Wed Mar 18, 2026 1:25 pm
 Post subject: Fuel line question
PostPosted: Sat Jun 09, 2007 2:35 pm
I am still piecing together my fuel delivery system with braided lines and have a question. I am building a streetable but mean 350ci motor.
Is it deterimental to change fuel lines sizes by a little bit as you travel from the gas tank to the carb? An-6 to An-8 and such?
1977 Chevy Luv
350/TH350
PostPosted: Sat Jun 09, 2007 5:30 pm
No it should be fine as long as your pump,pumps or regulator will keep the fuel bowls full it will be fine,i would steer clear of to big of line i have heard many horror story's of large fuel line all ending in fuel saturated floors or fire!.My vega has 6an braided line i will have some pics up some day,i also run 2 pumps,an electric in tank and the manuel block pump works great for me!
PostPosted: Sun Jun 10, 2007 1:47 am
On mine (alum. tank in rear) i run -8 from the tank to filter,pump, to reg., and then2 -6 lines to the carb.When i put the dual 4s on then i will make up longer -6 lines to fit the carbs.
PostPosted: Thu Jun 14, 2007 6:12 am
What are you talking -6 -8 and such. I just redid mine and run 1/2 inch aluminum line all the way from the tank to the y block and 3/8 braided to the carb.
