It is currently Wed Mar 18, 2026 1:26 pm
PostPosted: Thu May 03, 2007 1:09 am
I recently bought what I thought was a 350 but after running the serial numbers on the block and heads it turns out its a 302! I might drop it my luv or in my bel air or sell it, if its worth enough.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu May 03, 2007 7:05 am
Put it in your LUV you will like it. I had a 283 4spd in my LUV when i first built it and other then i had side pipes no one could tell.With the high reving motor it was allot of fun to drive and it was easy on gas. Because the 302 has no torq down low it would be perfect for the GM 14# flywheel and a t-5 trans and it can run with the big dogs and still get great gas milage.
PostPosted: Thu May 03, 2007 6:51 pm
the same numbers have been used on 283-350. check the bore and stroke if it is a 302 you can build 2 luvs for what some would give you for it. that is a hell of a find
PostPosted: Thu May 03, 2007 9:10 pm
I already took it apart and ran the serial numbers so Im sure its a 302. Whats great is I only paid $75 for the engine, but it's missing the original intake though.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu May 03, 2007 9:15 pm
Can someone say E-Bay
PostPosted: Thu May 03, 2007 9:22 pm
I agree you have a hell of a find be sure of what have and you will be surprised at what some will pay.
PostPosted: Fri May 04, 2007 12:43 am
Is it an MO stamped block?
Is the block an 3914678 casting?
Is this a shortblock?
Large or Small rod journals on the crank?
If you have the crank, give me the crank #.
Ill give you a value after that!
PostPosted: Fri May 04, 2007 1:48 pm
Long Block
Crank casting number is 3941178
Block casting is 3932386
I know that this is a 302
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri May 04, 2007 1:57 pm
Just re ran the numbers its a '69 not a '68 sorry. :oops:
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat May 05, 2007 12:19 am
Thems is 69 stuff, as you have already suggested.
386 block is Dec-March/May 69
Maybe later.
What is the bore and crank #s in respects to the last machining done to it???
Anyone else care to GUESS!
8)
PostPosted: Sat May 05, 2007 3:15 am
The engine looks to not have had any machining done to it other than factory. But it is very greasy so Im dropping off the parts at the machine shop monday to get all cleaned up.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat May 05, 2007 6:25 pm
well, IF it's a real one, make sure you trust your machine shop!
Otherwise it just may disappear!
Seen it happen a few times myself!
PostPosted: Sat May 05, 2007 7:58 pm
Any pics of the crank numbers?
PostPosted: Tue May 08, 2007 2:45 am
Dropped off the parts today wont get them back until thursday.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue May 08, 2007 12:14 pm
Swap Specialist Mod
if it is really a 69 dz302 block, then i dont think you fully understand how much its worth.
did it have a steel crank in it?
PostPosted: Tue May 08, 2007 7:46 pm
saw some on ebay for $1500 and up
