It is currently Wed Mar 18, 2026 10:21 am
 Post subject: Gas guage not working
PostPosted: Sat Mar 24, 2007 8:02 pm
My gas guage worked fine when I got the truck and now it doesnt work at all. I tried looking at the schematic on the site for the series 4 trucks but im stupid and it all looks like Chinese arithmatic to me can someone explain the wiring for the gas guage in a simple way.
PostPosted: Mon Mar 26, 2007 8:10 am
Use a test light and pull the wire off the sender and you should have voltage at the wire (blinking) if you do have voltage then your sender is bad , when you do this the gauge will read full and if you don't have a test light then ground the wire and your gauge will read full ,if you don't have voltage then you need to check at the gauge for voltage. If you have voltage to one side and not the other then your gauge is faulty,if there is no voltage then go to the power source.
PostPosted: Mon Mar 26, 2007 8:34 am
You wouldnt happen to know what color(s) the wire to the gauge/sending unit is would you?
PostPosted: Tue Mar 27, 2007 1:19 pm
Nope
