It is currently Tue May 26, 2026 12:15 am
PostPosted: Sat Nov 25, 2006 6:37 pm
I just got an 88 s10 for a v 8 swap. anyone know any helpful tips as far as what headers besides s10 headers might fit? If I need stronger springs in the front for the 4 banger swap out. I know you can stay stock with the 2.8. what would be a good vehicle to find the power stering pump from for the conversion? The rest should be easy besides geting 2.8 motor mounts kit and radiator. Thanks
PostPosted: Sat Nov 25, 2006 7:19 pm
I don't know of any headers that will fit besides the ones for an S-10. I will send you a pm.
PostPosted: Sat Nov 25, 2006 8:12 pm
Have you visited and S10 fourms?? Here are a few S10 V8 ones I am a member of
http://forums.s-series.org/viewforum.php?f=12&sid=ed5d5107104dfc393035e9ab9afb3f90
http://www.mys10.net/
http://www.s10forum.com/forum/forumdisplay.php?f=10
Hopefully you can find some info on those! :turn-l:
PostPosted: Sat Nov 25, 2006 10:31 pm
the s10 v8 conversion parts store.com as all the kits I dont like the shortie headers, plan on building my own.If the truck is going to be a streeter put good stuff springs etc in it for 1/8 mile drag the stock springs are ok.
I land speed race mine 1 mile , springs are ok, but I need to lose about 200lbs off the front and add 50 to the rear to have 51% front .
PostPosted: Sun Nov 26, 2006 3:44 am
Swap Specialist Mod
check out http://www.v8s10.org
tons of good info on there.
PostPosted: Mon Nov 27, 2006 10:28 am
Thanks everyone.
