It is currently Sun Feb 01, 2026 8:39 am
 Post subject: C- clip axle removal
PostPosted: Sat Jun 03, 2006 6:26 pm
Is there an easy way to remove a c- clip from an axle while its installed in the housing? I was trying to remove the axles from my ford 8.8 rear end but gave up after only trying for a few minutes I had to leave and have not yet had a chance to go out in the garage. I tried using various flat head screw drivers and a small prybar and hammer. Any advice would be greatfull.
PostPosted: Tue Jun 06, 2006 10:06 pm
Japanese Redneck
try pushing the axle in first, remove C clip and then slide axle out. LMK if that works
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Wed Jun 07, 2006 5:51 pm
I was kinda going about things in a dumb way. My brother came over popped out the pin that holds the 2 spider gears in place and said ok try it now, and to my amazment they flew off effortlessly. I felt so stupid after he did that but I guess we all have to start somewhere.
PostPosted: Wed Jun 07, 2006 8:07 pm
yeah the center pin for the spiders gears also acts as a thrust block. That keeps the axles from coming in any and thus keeps the C-clips in the reces in the carrier to keep them in place.
