It is currently Sun Feb 01, 2026 10:24 am
 Post subject: Quick Fuel Technology
PostPosted: Fri Jul 14, 2006 11:32 pm
Just installed a QFT 750 double pumper carb on my luv. I cant get rid of the huge bog off idle. Had 780 vac secondary and had no problems. the carb is in tune I did it and had a friend check. I tried the primary pump nozzle off the vac secondary changed 33 to 37 with no luck. Do I need to go smaller on the pump nozzle because it is a double pumper? I am a novice with a DP carb is there any pros out there? Maybe secondary cam adjustment it has the pink one. Have got 550hp 383ci it has run 7.40 several times in the 1/8 with the vac secondary on 9inch street tires through the mufflers.
PostPosted: Mon Jul 17, 2006 5:51 pm
8O You should have stayed with the vac. secondary carb, but try at least 6 deg. more timing as you now have to burn more fuel sooner. :?
