It is currently Sun Jun 14, 2026 12:53 am
 Post subject: oil leak, help!
PostPosted: Wed Jul 14, 2004 3:07 am
i have a 1985 nissan stanza with a 2.0 in it and it seems to be leaking oil from the main pulley on the engine really badly. This is a bearing seal probably? Im just curious how this is fixed and how big of a job it is. Thanx in advance!
PostPosted: Wed Jul 14, 2004 4:34 am
Sounds like a main seal. If you are able to get the pully off, and pop out the old seal, then use a big socket to pound in the new seal, and you should be good. GOOD LUCK :D
PostPosted: Wed Jul 14, 2004 12:43 pm
probably just need a pulley puller ya? Its that simple tho? Just take the pulley off, take old seal off and pound new one in?
