It is currently Sat Jun 13, 2026 11:38 pm
PostPosted: Mon Jan 12, 2004 3:13 am
Alrighty when i tore down my troopers 2.6L i found that #2 cylinder was washed whith gas. Obviously the injector was giving this cylinder too much fuel and it was flooding. Anyone know what can couse this and possibly fixes?
PostPosted: Mon Jan 12, 2004 7:17 am
Injector solenoid stuck open, return spring bad. I'm thinking basically if the valve doesn't close it's going to be dumping fuel all the time. You could find a shop to test it or just replace it.$$ Not sure if you could test it on your own :? You might want to replace the lines too while your at it.
Resident lurker
PostPosted: Tue Jan 13, 2004 8:31 pm
The injector "O"rings may be bad.I had that happen and filled the exhaust system with fuel.Get a ohm meter and test all your injectors too.
PostPosted: Sat Jan 17, 2004 5:39 am
well i took my injectors to my uncle and he flow tested then rebuilt em. One injector wasnt flowing well and they were all leaking. That was probly my problem :)
