It is currently Sat Jun 13, 2026 9:38 pm
PostPosted: Mon Jan 25, 2016 7:45 pm
So I bought this..http://www.ebay.com/itm/291641799742?_t ... EBIDX%3AIT
Put them in yesterday. Super easy install and all went well. But when I turn the wheel, I get a rubber on metal sounding squeak out of both sides, the right worse than the left. Where did I go wrong? Is there a secret trick I missed?
Oh, this is on my 1998 Ford Windstar mini van. Don't be jealous, you can can by one for yourself too. :lol:
PostPosted: Mon Jan 25, 2016 7:51 pm
I would guess the noise you hear is from the top mounts. When I was at the dealer that was usually what made the noise.
PostPosted: Mon Jan 25, 2016 7:56 pm
That's where it sounds like it's coming from. That's where the, what they call, the bearing is. The assembly turned by hand nicely before I put the hub assembly on. but all done and on the ground and I have this squeak. :econfused WD40???
PostPosted: Mon Jan 25, 2016 8:18 pm
You can try WD40. My experience has been the rubber squeaks where the bearing is.
PostPosted: Mon Jan 25, 2016 8:25 pm
OK thanks, I'll drive it a few days and see what it does. I may have to dig into it again this weekend.
It does ride much nicer with the new ones though. 8)
